Hello propeller hive-mind!
I recently acquired a propeller and I need help identifying it. I want to know if it is authentic and was originally used as a propeller or it is a propeller build as a decorative piece.
It measures 2,80 m and it has some markings on the hub (FOKKER D 7? and SE 6(or G?)A underneath the SE6 it has some numbers which I believe are 1 2 2, but not sure) (see photo's)
It has been used (originally or rebuild?) as a decorative piece and it has a clock mounted in the hub.
If you need any further information, just ask and I will gladly provide you with it.
Thanks already for any information provided!
PS: I want to thank Mr. Bahnson for his help getting me logged in on this forum. He was/is very responsive and helpful, he checked several times his software to find the problem. Now we discovered that the problem was with my BitDefender Security software which blocked the sending of the password over a non-secured connection. I just had to add WoodenPropeller.com as an trusted website and the problem is gone! So thank you very much Mr. Bahnson for all your patience and assistance! (And for other newcomers to this website, this info can help preventing the same issue)
