Old 04-21-2019, 04:15 PM   #1
ahranis
Wink ID Please?
Found in my late fathers basement.
I was about to try to restore it. I then found your site and changed my mind.
I suspect that someone has done it allready before me.
No background history that I know.
length: 2,79 meters
number of bolt holes: 8
I cant be sure about the stamps...
Helics (Les ....- Paris) decal
Serie 550
No .(3?)203
MI
Cu 260
Sal
SFA (0?)
In the photos you can spot various unidendified signs at the hub.
It was a big thrill trying to match the readings to your sign list!
I am not interested in selling it. I would be happy knowing the type of plane
and approximately the year of manufacture.
Thank you anyways!
Geetings from Greece.
ahranis is offline   Reply With Quote
Old 04-21-2019, 08:14 PM   #2
I think the decal is the one attached (Les Fils de Régy Frères - Paris - / HELICES RF).
The markings seem to be for a Salmson 2A2 aircraft fitted with a Canton-Unné Z9 engine, but the serial number 550 seems to be absent of known databases and the 350 was for AR1 or AR2 with 170 HP engine... So, it is a French interesting prop!
Could you:
- post pics of the two "flat" sides of the hub,
- confirm that the marking "M1" is on the same side that SERIE and N°?
- confirm that the marking on the opposite side is "c1"?
- post a very close up pic of the serial number,
- give the blade width (at the larger place which is around two third of the blade),
- try to know if the tip protection is made of pigskin or parchment.
EDIT: Replaced link by file for the decal.
Old 04-22-2019, 03:12 AM   #3
ahranis
Well,
I am really thankful for yor quick and detailed responce!
- These are the new pics.
- The "M1" marking is indeed on the same side as Serie and No.
- About the opposite side, I reattach a pic of an unidendified mark (NF?) beside of a possible C1,
both spotted, next to a rectangular one (bottom right).
- The blade width is approximately 23 cm.
- I am not quite sure about the tip protection. The material is quite thin, hard
and transparent with follicles visible in places.
Again I am really thankful for your time and effort,
Nick
Old 04-22-2019, 03:15 AM   #4
ahranis
more pics...
Old 04-22-2019, 03:17 AM   #5
ahranis
last one
Old 04-22-2019, 03:19 AM   #6
ahranis
P.S. The decal on your reply was not visible to me for some reason...
Old 04-22-2019, 05:27 AM   #7
Thank you for the new pics. I have change my first post and I think the decal is now visible.
The marking Nf is for Noyer de France (Juglans regia), the wood used.
The possible "c1" have to be a lowercase C (at the opposite side, the "M1" is (and has to be) a capital M): it is the way to show that the prop has been repaired or modified.
I will look at your pics and try to find more details but I have to search in my papers...
Old 04-22-2019, 07:07 AM   #8
It doesn't look "restored" to me, even though as PM says it may have been "modified" at some point, so it's a very nice collectible item as is.
I still have a similar prop used on the Salmson A2A. Now I'm wondering if mine was actually manufactured by Regy, although it's not apparent from markings on it. It does have a Regy "look" to it though, similar to yours.
Note the similarity (and differences) with a Regy prop for a Caudron:
Old 04-22-2019, 07:27 AM   #9
ahranis
Yes, I've been in that page often since I spotted your site!
Now that my eye is "trained" a little bit more, I can spot more similarities and the differences...
Very beautiful and well preserved!
Old 04-22-2019, 07:30 AM   #10
ahranis
Thank you pmdec...
