Prop from Curtiss R-4?
  • Prop from Curtiss R-4?
    Hi All
    A friend has found in his late father's extensive collection of aviation artifacts a wooden propeller 9'6" marked 11612 which I believe closely matches the Curtiss R-4 prop in the webpage http://www.woodenpropeller.com/R4.html. Any confirmation or alternative suggestions are welcome and greatly appreciated. He may be interested in selling it. If so, I will post again.
    Thanks, in advance,
    John
    Yes, it's pretty clearly identifiable, and it's the same model that's used on the Curtiss R9. They were manufactured in large quantities and many were sold off as surplus in the 1920s or so
    Whether he offers it for sale or not, it should be kept in its present condition.
      Thanks for the info!
      The owner's late father wrote on a piece of paper that it was used with an OX-5 engine. I can't seem to find any documentation that might confirm the use of this prop with the OX-5, only the Curtiss V-2 and V-2-3 engines. Thoughts?
        No, I think it's the wrong size to fit an OX5 hub, which has a bolt hole circle diameter of 5 1/4". If you measure from the center of one hole to the center of the hole furthest away, that represents the bolt hole circle diameter. I think you'll find that your prop has a larger bolt hole circle. See attachment for model number reference.
