4 Blade Prop
  • 4 Blade Prop
    Saw this on everybody’s favourite online auction site.
    At first I thought it was a test club but after further inspection I think it is a cut down propeller.
    It hasn’t had a bolt circle drilled and is stamped “DRG T2950”.
    Any thoughts?
    https://www.ebay.co.uk/itm/vintage-w...wAAOSwxzxfncFx
    You could be right.
    My Fiat coupe 20vt had Borletti clocks though.
      Looks like an RAF target tug, winch generator propeller.
      There are a few posts about them:
      http://woodenpropeller.com/forumvB/s...ead.php?t=3760
      http://woodenpropeller.com/forumvB/s...ead.php?t=3345
      You can see on in use in the below photo:
        I do believe you are right. I hadn’t appreciated the scale from the photos.
        Interestingly, one of the threads that you linked to mentions T29506 as being the drawing number for a target tug application. On closer inspection, I think this one has an extra digit which I can’t decipher, although I don’t think it is a 6.
        Seems reasonable, though, that a drawing number in the T2950x series would also be for a target tug winch.
        Mystery solved; thank you!
          I think test clubs have a constant pitch angle from the hub to the tip vs. the changing angle all along the blade of a propeller designed for propulsion or power generation.
