Old 03-02-2016, 12:58 PM   #1
Check6
Default I D help please.
I have a barn find and would like to know what I have.
This is a black wooden propeller.The only markings on it are u.s propellers Inc.
It measures 96inches and 6inch thick.
The hub has various marks.
One side...258716
The other has....D2827
Assem 41g2325
Cont.w33-038ac549
Sri set.no 24007
? Thank you for any info you might be able to help with.also if this is servisable does it have any value?
8 bolts on hub
Check6 is offline   Reply With Quote
Old 03-02-2016, 02:01 PM   #2
I doubt that it would be airworthy at this point. U.S. Propellers did not make a lot of props for certificated aircraft. Most of them seem to have been made for drones. I've never seen a list of U.S. Propellers correlating model numbers with aircraft usage.
Old 03-02-2016, 07:39 PM   #3
Check6
Wink Reply fairchild propeller
Thank you.I found the propeller along with some fairchild parts ,just curious if there was a connection
Old 03-02-2016, 10:14 PM   #4
I'll check what little resource I have, but that company has been a frustrating one to research.
Old 03-03-2016, 09:29 AM   #5
The attached is ALL I have for U.S. Propellers. There is only one 96" propeller listed (Model 96LG) and it has a unique Type Certificate number (79. As I mentioned, I know of no available lists that would correlate that model number with aircraft application. Can you post a picture of the prop and the hub?
