Old 07-24-2018, 08:27 PM   #1
jschoppaul
Default Early Wooden Propeller. 6 Holes, Chauvier type
I bought this at an antique store a few years ago in the states. The owner bought it at an antique store in France in the 70’s.
1) There are NO identifying marks.
2) 6 holes, a distinguishing characteristic.
3) Does appear to have been mounted various times.
Tip to tip 82 1/2” ( 209.55 cm )
Holes appear to be 5/16” ( 0.794 cm )
Hub thickness 3 1/4” ( 8.255 cm )
Shaft hole 2” across ( 5.08 cm )
jschoppaul is offline   Reply With Quote
Old 07-25-2018, 06:27 AM   #2
It is not a Chauvière. Could you post pics of the sides of the hub?
Pierre-Michel
Old 07-25-2018, 01:40 PM   #3
And it doesn't look like a British made prop. The apparent pitch and the diameter of 2095mm suggest a small aircraft with a comparatively low powered engine, I think.
Over to you Dave!
Old 07-25-2018, 03:55 PM   #4
jschoppaul
Default Early wooden propeller
Thanks for the replies,
I’ll try to be quick on my end.
Old 07-25-2018, 04:29 PM   #5
Over to you Dave!
I don't know what it is either, and I doubt that it can be identified. Note that on the side view it appears to be a solid piece of lumber, unlike most other propellers, which are laminated.
Old 07-25-2018, 05:31 PM   #6
No laminations, no flared side of the central hole and very small bolts... It could be a very very early prop, or, more probably, an amateur construction. Perhaps not for an aircraft.
I don't see how it could be identified... Do you know which wood it is made of?
Has your phone or tablet a built in clinometer? Do you know how to measure the pitch?
Old 07-25-2018, 10:53 PM   #7
jschoppaul
Thanks again for all your help.
1) Yes, it is a solid wood propeller, no laminations.
2) It does look like it was used. There are hub markings from compression, tip damage ( slight ), and leading edge wear.
I tried to measure pitch. Bear with me on my math.
I used to formula of:
PITCH = 2.36 x diameter height / width.
I measured “diameter height” of 1 7/8” or 1.875” at the 75% mark.
I measured the “width” at the 75% mark as 7 3/8”, or 7.375”
So, 2.36 x 1.875 / 7.375 = .6
Does this sound reasonable?
Thanks again for everyone who is trying to help. Even an “age” range would be nice.
John Schoppaul
File Type: jpg B25E5B02-0A8F-42C3-88A3-A6982C1644D2.jpg (86.9 KB, 4 views)
Old 07-26-2018, 06:52 AM   #8
Looking at the photographs of the side of the prop shows it be thinner than I expected.
I doubt if we can offer any more help. You might wish to explore photographs of every early aircraft you can find on the internet, starting with the Wright Brothers; and also Google early hand-carved aeroplane propellers. Let us know if you find something.
If your prop is an early hand-carved American or European propeller it is of historical importance.
And I enjoyed looking at your cat. When I was writing my books on British WW1 props about ten years ago, I took illustrative photographs outside in natural light and was always accompanied by one or more of our cats who joined in the process to see what the human tin-opener was doing.
Old 07-26-2018, 06:59 AM   #9
A postscript: you might also wish to find a dendrologist at a local university who would be able to date the wood from the rings, but they would need to bore a hole to obtain a sample.
Old 07-26-2018, 02:01 PM   #10
jschoppaul
After your comment ( appreciated ), I re-measured the bolt holes.
I was mistaken, they are actually 3/8” ( not the 5/16” I quoted earlier ).
Thanks again everyone.
