Trying to identify
  • Trying to identify
    IMG_0146.jpgTrying to identify prop. Looks like a Hartzell from other pictures in this forum.
    100 inches long. Bore = 2 3/4 inch, eight 3/8 inch bolt holes, 4 3/8 in. thick at the bore. Flange diameter = 7 1/2 " Numbers visible= SC4100, Copper metal on tips and part way up leading edge. Small diagram visible which looks like a 4 leaf clover with the letters U, S, A, one in each clover leaf.
    Can you post pictures here? I'm going to guess that the SC4100 is a US Signal Corps designation.
      Flight mech
      Pictures are posted also a couple of other items noted.
        I'm guessing that it was designed either for an OX5 engine or a Hall Scott A2A engine. They are very similar, but the bolt diameter circle for the Hall Scott is 6" instead of 5 1/4" for the JN4. See this page for details.
        The geometric shape is very similar to this Standard J1 prop, but it's a few inches shorter than yours is. (But here is another J1 prop that is 100" diameter.)
