I have a 1917 Aerothrust boat motor, the existing prop is 32 inches. This motor runs at about 1000 rpm and is about 6 to 8 HP If you have a early longer prop with a banged up end, I can cut it down and refinish it to suit. This is a display motor and will not be used. Remember its a pusher so an airboat type prop is what im looking for.
Next
I have a 1950's pusher airboat motor that needs a 36 inch prop again I can cut down and needed if you have one with a banged up end. This is also a display motor from my collection of very early outboards and inboard marine engines. This one used a belt driven jackshaft so I can turn a hub as needed. prop speed about 1800 rpm's from a 10 HP running a 3 to 1 ratio. If you can help with either let me know.
and yes Im following Ebay [/b]
					Next
  rpm's from a 10 HP running a 3 to 1 ratio. If you can help with either let me know.and yes Im following Ebay [/b]
 [/img]
[/img]
