Old 09-02-2008, 04:03 PM   #1
tnowak
Default Prop with no markings
Greetings,
A friend of mine's old aunty has a propeller which belonged to her late husband. She is considering disposing of it and wondered if I could help identify it. Although I fly a classic aeroplane (Piper Vagabond) I am not an expert with "old" propellers so am looking for help. Firstly, the details:
1. No markings whatsoever on prop
2. Diameter = 80 inches
3. Hub thickness = 4 inches
4. Prop bolt holes = 0.6 inch dia (qty
5. Hub diameter = 9 inches
6. Rotation (viewed from front): counterclockwise
Pictures at: http://s361.photobucket.com/albums/oo53/tonnowa/
Hub dimensions appear to be fairly standard (having looked at the Sensenich hub page). I haven't seen the prop myself and the measurements have been passed to me by the aunty. May need to be doublechecked!
Any thoughts as to possible engine / aircraft? You will note that the leading edge of the blades sits forward of the hub.
Regards
Tony
Old 09-02-2008, 05:04 PM   #2
Without markings it's almost always just a wild guess. The leading edge protusion is unusual, but is similar to this propeller...
Old 09-03-2008, 06:27 AM   #3
Good Morning Tony,
The prop has all the hallmarks of a design by Dr HC Watts of the Airscrew Company of Weybridge. Flight magazine observed that they produced 80% of British wooden props between the wars. They continued making wooden props until the 1970's.
In the mid 1930's they stopped stamping the data on the hub and instead screwed a small brass plate near the hub. These are often missing these days but traces of four screw holes can sometimes be found, describing a plate about about 2 inches by 1.5 inches, often located on or near those raised humps either side of the hub.
An 80 inch diameter (6.66ft or 2030mm) suggests a light aircraft. Possibilities include drg no Z 8010 for an Auster, and Z 6011 for a DH Moth, both of which had DH Gypsy engines, but the best candidate is a DH Tiger Moth with a Gypsy Major engine, where the prop is listed as 6.67ft, drg no Z 6013/1/A . Large nos of Tigers were made as training aircraft during WW2, so statistical chance reinforces this liklihood.
They are fairly common in GB and sell for about 250 gbp at auction.
With regards,
Old 09-03-2008, 08:04 AM   #4
Bob, weren't the Gypsy engines Left Hand rotation?
This one is Right Hand.
Old 09-05-2008, 05:20 AM   #5
tnowak
Bob,
Before seeing pictures of the prop I assumed it would be for an Auster / Moth or similar. However, seeing it was for a CCW rotation engine made me think it would be for something quite different.
I know that some Austers have Lycoming engines, but the prop style and size doesn't seem to make that likely.
I have asked the the prop to be examined for screw holes.
Any thoughts as to what engines of that "prop era" are CCW rotation? I believe some license made Cirrus/Gipsy engine in USA rotate in that direction.
Tony
Old 09-05-2008, 10:05 AM   #6
Hello Tony,
I can't offer any help along these lines, really. I don't know much about engines.
The prop is a Watts design and the diameter matches drg no Z 6013/1/A. This is the limit of my ability. I am slowly building up a database of Watts drg nos. Sadly they threw all their archives away when they closed their prop dept in the 1970's.
Let me know if you discover anything else.
Old 09-05-2008, 10:07 AM   #7
As a postscript, the thought occurs that Gypsy engines might have been handed for use in two engined aircraft?
Old 09-07-2008, 06:49 AM   #8
tnowak
I asked my friend to ask his aunty to check for four small screw holes. Well, aunty's eyesight must have improved (!) as she found 7 lines of information on the back of the prop!
2nd line reads DRG 0 581/1
3rd line reads WASP 2 JUNIOR
6th line reads D7 25 1791
7th line [very hard to read] it could say 777
So, I assume the prop is for a Wasp 2 Junior radial.
Any other useful history info from the above technical data?
Typical value now?
Regards
Tony
Old 09-07-2008, 06:52 AM   #9
tnowak
Typical value now?
Regards
Tony
Old 09-07-2008, 08:04 AM   #10
This becomes more difficult. I don't have any data for a British fixed pitch prop made for the P & W Wasp Junior. This engine was powerful, 450hp onwards, and probably was only used with a variable pitch prop. However fixed pitch props might have been used on RAF Ansons, Oxfords and the Northrop Nomad taken over from a French order.
I'll do a bit more research and come back.
