Old 12-28-2007, 01:00 PM   #11
abufletcher
Wow! Great photos! What is the diameter of this prop? Also were generator props always right-handed props (rotating clockwise when viewed from the front)?
Old 12-28-2007, 02:06 PM   #12
This prop is eighteen inches in diameter. I don't know if they were all RH rotation; as they were designed by humans, I doubt it ! Would the direction of rotation matter for a generator prop? If it generated a sine wave, would the result not be the same either way?
Old 12-29-2007, 07:29 AM   #13
kronos
JUST GOT THE TAPE OUT AND THE PROP IS 485MM IN DIAMETER
Old 12-29-2007, 07:32 AM   #14
Thanks kronos !
Old 12-29-2007, 07:53 AM   #15
kronos
HI BOB
IF ITS ANY USE, WHILE CHECKING THE BACK OF THE HUB THERE IS A SECOND "AID" STAMP WHICH WHEN YOU USE A TORCH TO CAST A SHADOW ONTO IT REVEALS IT TO BE H43
REGARDS ANDREW
Old 12-29-2007, 11:30 AM   #16
Excellent. Thank you. Another one for my database. What is your surname Andrew? So that I can credit your photos in volume 2 to you. At the moment you are merely Kronos; it's time I changed that!
With regards,
Old 12-29-2007, 05:22 PM   #17
abufletcher
What is the thickness of this interesting little laminated prop? And how many laminations does it appear to have?
Old 12-29-2007, 07:08 PM   #18
kronos
THE HUB IS 32mm OF WHICH 28mm IS THE LAMINATIONS AND THE OTHER 4mm IS METAL FACE PLATES. THERE ARE FOUR LAYERS OF TIMBER IN TOTAL.
