Old 07-28-2016, 05:55 PM   #1
Stuart
Default Hi help needed
Hi sorry I'm new to this forum and needs some help.
I brought this on Sunday and wondered if you could tell me all about this.
The guy said it used to have a clock in it
Stuart is offline   Reply With Quote
Old 07-28-2016, 06:11 PM   #2
I don't have my reference materials handy, but when I do it should be easy to identify by its drawing number AB728. I suspect that the "W.D.O." refers to WD Oddy, the manufacturer.
Old 08-02-2016, 10:00 AM   #3
'Morning Stuart,
This hub data dates from around 1918 and came from a four-bladed prop designed for the Handley Page O/400 bomber. It was designed for the Rolls-Royce Eagle engine but shortages of this engine led to others being used including the 200hp Hispano-Suiza engine.
Your data translate as:
AB728: the drawing number of the propeller, designed by the Air Board.
Left Hand: the direction of rotation. The RR engines were handed to prevent swing on take off.
Hispano Suiza: the French engine of 200hp.
D2740: the diameter in mm.
P2730: the pitch in mm.
WDO: This might well be the initials of WD Oddy, a firm making propellers in Leeds but they normally stamped their name in full as WD Oddy and sometimes as Oddy and I have not recorded any other similar props made by Oddy, but they probably made this one.
Comparatively few HP O/400s were made with the Hisso 200hp engine so it is unlikely that you will ever see another, but such rarity does not affect its value which is comparatively low.
