Old 07-12-2014, 05:35 AM   #1
Beanz
Default Can you identify my propeller?
Hi
I've had a wooden propeller (that unfortunately was cut down long before I bought it) for over 30 years. I'm only now getting around to putting it on the wall and I thought it would be nice if I could have some knowledge on what it was from.
It has 8 holes in the hub and on one side of the hub it has the following:
DRG.NO.5220.ISS.5.M D.6.33' P.4.58'
And on the opposite side of the hub:
HRA.438.G 6/72
I think it's also got LHT (which is the only thing I do know the meaning of!).
From reading past posts on this site I believe the DRG refers to drawing number, 5220 refers to a Moth (what sort of Moth?) the D.6 part refers to the (6 foot?) diameter and the P is the pitch (which I'm guessing is 4.58 feet?). HRA is for Horden-Richmond Aircraft and the final part 6/72 refers to June 1972. However I may be way off.
If anyone can give me some info on this or clarify what I'm right about I'd really appreciate it. Many thanks
Beanz is offline   Reply With Quote
Old 07-12-2014, 07:40 AM   #2
I think you're conclusions are all correct.
Bob Gardner might be able to offer some additional insight, but often just narrowing it down to a grouping of aircraft/engine models is as far as you can get.
Old 07-13-2014, 05:26 AM   #3
Beanz
Thanks for that info. If I understand it correctly, this means my prop may have been from a Moth but it's in no way certain. I was trying to explain this to my partner yesterday and the way I described it to her is to imagine a car tyre. It may be a 155/70 and yes, that may well fit a (say) Mini but it could also fit other small cars. Hopefully my understanding is correct.
If so, is a Moth ONLY a Tiger Moth or Puss Moth or are there other Moth aircraft?
