Old 06-12-2014, 07:23 PM   #1
ERICLINDROTH
Default my fathers prop
it is -MATTHEWS BROS. 10' 0" R.H. BRASS CLAD ON LEADING EDGES , THE FABRIC FELL OFF OVER 50 YEARS AGO ,8 HOLES ,OTHER NOMINCLATURE
N9443 , SE5111 , F-5-L , ...IT LOOKS SIMILAR TO TWO OTHER PROPS I SAW ON THIS SITE...I WOULD LIKE TO LEARN MORE ABOUT IT, CAN ANYONE
HELP? THANKS ERICLINDROTH
ERICLINDROTH is offline   Reply With Quote
Old 06-12-2014, 09:27 PM   #2
It's most likely designed for the Felixstowe F5L, based on the stampings. The "SE 5111" is the drawing number, or blueprint number, that describes the shape of the propeller, with "SE" referring to "Steam Engineering", the Navy department that was in charge of procuring propellers for the Navy in the late teens. The bolt holes should be 8" apart across the longest distance across the hub, which is the size of the hub for a Liberty engine.
Many propellers look the same, but are distinctly different in their design and applications. There were thousands of different designs by the end of WW1.
felixstowe f5l, liberty engine
