Old 02-23-2006, 07:26 AM   #1
jake2157
Default propeller info needed please no pics yet
i have a propeller with the stamping on it as follows:
Airship OB-1
Stnd.R.P.M.
Eng.Lawrence
Part No.066422
A.C. No.28-2800
with the measurements of hub thickness 4 1/2"
hub diameter no metal 5 3/4"
Center bore 2 5/8"
bolt size 3/8"
bolt circle 4 1/2"
if you know of a web site where i can research it myself or any help would be great
Old 02-23-2006, 10:36 AM   #2
Does it by any chance look like this propeller? I can measure the hub dimensions later, but this is one of the few props that used the Lawrance engine.
Old 02-28-2006, 05:30 PM   #3
jake2157
Default prop with no pics again
it is a lawence but it does not look like the one you have in that photo dave it has a rounder cut edge in stead of the point on it it is a dark color wood and has a round cutting edge with a half moon type design on it 7 of them then on the end it has a straight line in off the edge about 4" i cant take a good enough picture of it to show you it is all one piece design on it . also right know there is a pic of a prop on top of this forum that has the general shape of the prop i have but no gray on it ... i'll try to get some more pics tonight but not having luck on good ones which shows details any ideas ?
