Go Back   Wooden Propeller Forum > Design and Manufacturing > Manufacturers
Old 05-03-2012, 02:24 PM   #1
pipermak1
Default Is this the real thing or is it a Mantle Piece?
Have a beautiful wood propeller that I have not been able to locate any specifics on so I found this site and thought y'all might be more knowledgeable than I.
If is light colored with medium red tips(squared off tips). I have pictures and they are attached.
The ONLY markings on it are around the hub and are "US" and "45A" using what appears to have been 1/4" steel impact stamps.
It is likely to have been re-finished as I do see 1 drip spot on the trailing edge of 1 blade.
Can you help me?
Mark
pipermak1 is offline   Reply With Quote
Old 05-03-2012, 03:16 PM   #2
MWP_Lamar
I've not seen anything like this that I remember. There are a few things that would lead me to believe it's made as a decoration:
1. There are no protective metal edges or tips on it although it could be a drone prop with the red tips.
2. There are no witness marks although it could be just unused.
3. The shape of the blades look suspect to me; they are way too narrow.
4. There are what appear to be knots in the wood right where at least two of the bolt holes are drilled; real props NEVER have knots. Not even drone props.
MWP_Lamar is offline   Reply With Quote
Tags
45a us
