Old 02-07-2011, 12:38 PM   #1
Walter
Default early WWII wooden propeller
I have a never used, fine condition wooden propeller with the following markingsES 76FGSA-64, SER 10873, RPM 2200, HP 113, TO (or TC) 787. Approximate measurements tip to tip are 76". It has a US Propeller decal on each blade and a 4 bolt pattern with 7/16" holes, a center hole approximately 3". The tips and leading edge appear to be brass. Can you identify it for me and give me your best guess as to value. Thanks, Walter
Walter is offline   Reply With Quote
Old 02-08-2011, 12:03 PM   #2
Does your prop have red tips? The four bolt hub pattern indicates it's not an aircraft prop but perhaps a target drone.
Old 02-08-2011, 02:27 PM   #3
Walter
Default Reply to Lamar
Thanks for your prompt reply. The tips are not painted red. They are metal as are the leading edges, covered in metal. Any further information will be appreciated.
Old 02-08-2011, 05:37 PM   #4
Are the tips flat rather than curved? Can you post a picture?
Old 02-09-2011, 06:27 AM   #5
It sounds like a certificated propeller for one of many possible training type aircraft from the 30's up to the present, so that doesn't narrow it down much.
I'll try to check some numbers when I'm home in a few days.
Old 02-09-2011, 01:35 PM   #6
Walter
Talking Reply to Dave and Lamar
Thanks to both of you. Lamar asked if the tips were flat or curved. They are curved. Dave thinks it might be from a trainer. I can post as picture if you think it will help. It may take me a couple of days. Thanks!
Old 02-09-2011, 02:22 PM   #7
In this case a picture may be a great help. Thanks.
Old 02-09-2011, 07:51 PM   #8
Walter
Smile Reply to Lamar
Thanks for the quick reply. I should be able to take the picture tomorrow and I'll send it along as soon as I figure out how.
Old 02-10-2011, 11:49 AM   #9
Dave has written an excellent tutorial on how to post photos here: http://woodenpropeller.com/forumvB/s...=2733#post2733
Old 02-12-2011, 06:03 PM   #10
Here are Walter's pictures.
