Old 05-16-2010, 08:44 AM   #1
JenSed
Default Propeller clock
Hi
In my late father's possessions I found a propeller clock. It sits in the hub and there are no blades. The clock part works and is made by Davison and Partner Ltd Stockton on Tees
On the bottom on the hub is the following
503
110 Le Rhone
504K
520N56
Dia. 27
Pitch 36S
On the top
G520N5
Can anyone help with the date - I'm thinking WW1?
Where would it have come from? My father was an RAF pilot (WW2 - 1983)
Jenny
Old 05-17-2010, 06:13 AM   #2
Good Morning Jenny,
The details on the hub show that the prop was designed by Avro (Y503) and was made for a French engine of 110hp made by Le Rhone (110 Le Rhone) for a Royal Flying Corps training aircraft, the Avro 504K. The diameter and pitch of the prop were 2740mm and 2655mm respectively.
The batch number of G520 indicates that it was made late in 1917. N56 indicates that it is the fifty-sixth prop in that batch of 100 props.
If you sold it at auction here in the UK it would make about 200 GBP, about 300 USD. If you decide to sell it, let me know and I'll advise on the best auction house to use.
Could you look closely at the hub and see if you can find some small squares, usually four in a group, with AID in them and a number under the AID. Each square is tiny, smaller than the finger-nail on a little-finger. These are airworthiness stamps and I would like the details for my database that I am building up. Often they are not legible.
Old 05-17-2010, 08:37 AM   #3
oinkitt
Default Hi Bob - here are all the numbers off my prop
I am quite fortunate in that all my impressed info is very crisp.
TOP
130 H.P. CLERGET
110 H.P. LE RHONE
DRG Y 503
690
87
R.H.
BOTTOM
G. 1503.
N. 84.
R.H.
FRONT INSIDE FRONT
AID AID G1503
652 652
AID AID N84
652 652
Adrian.
Old 05-17-2010, 02:44 PM   #4
JenSed
Good afternoon Bob and thank you for your very speedy reply
What a wealth of information from a few numbers!
I've looked all over the hub but sadly I can't find any AIM squares - were they always in the same place? Perhaps the clock face is obliterating them?
At present I don't intend to sell the clock as its a very precious reminder of my late father but should the need arise I'll certainly get back to you if I may
Best wishes
Jenny
Old 05-17-2010, 02:46 PM   #5
JenSed
Default Sorry!
Sorry Bob - read AID numbers not AIM!!
A Senior Moment I'm afraid!
Jenny
Old 05-17-2010, 03:29 PM   #6
Hello Jenny,
I am glad to have been of help.
Thank you for looking for the AID numbers,
Old 05-17-2010, 04:00 PM   #7
Thanks Adrian, for the info from your Avro 504 prop. The G number suggests that your prop was allocated its G number in late 1919. I have added the details to my database.
Old 07-20-2016, 09:06 AM   #8
Paul and Toby
Dear Bob,
We recently bought a wooden propeller clock here in Sydney NSW.
If appropriate please feel free to include our propeller (with French clock) in your register. From previous posts to Jenny looks as if it came from an Avro, but we would appreciate your opinion on its origin.
GY 503
10 . LE. RHO (cut off here). Cannot see an extra ‘1’ to indicate 110 Le Rhone
2655.
28 (chipped edge)
Rear of propeller: 35
No square punch marks or AID seen
8 bolt holes.
Any information would be appreciated.
Many thanks,
Paul and Toby
Paul and Toby is offline   Reply With Quote
Old 07-21-2016, 06:13 AM   #9
'Morning Paul & Toby,
The drawing number Y503, where Y indicates Avro, is for a prop made for the Avro 504K, as you suspected. It had the 110hp le Rhone engine, as the markings suggest.
Old 07-22-2016, 10:16 PM   #10
Paul and Toby
Thanks very much Bob. We hope the details can join your database.
best wishes
Paul and Toby
