WW1 Wood Propeller
  • WW1 Wood Propeller
    Hi;
    I have a propeller which presumably is off a SE-5a which bears the engine name on it HISPANO SUIZA WOLESLEY VIPER
    I have numbers on the propeller which i am unsure of,presumably two of them being the drawing number and the serial number.
    I would be grateful if someone would be able to inform me what these numbers refer to and if there are any old records available as to its tracability to a particular aircraft?
    Numbers shown are;
    GL433N51
    4937
    AB662GBH
    D2400
    11750
    Thanks;
    Regards Dave
    E-Mail davegribble@inspire.net.nz
    Hi Dave,
    Sadly props are not traceable in any form and certainly not to aircraft. Your drawing number, AB662C RH, indicates use with an ungeared Hisso 200hp engine and the British version, the Wolseley Viper. The prop was used on the SE5A and the Sopwith Dolphin, Diameter and pitch are 2400mm and 1750mm.
    With regards,
    www.aeroclocks.com
      Reply Re WW1 Propeller
      Thanks for the info on the propeller Bob.
      Interesting that they displayed the Diameter & Pitch in mm. That confused me as i expected to see those measurements in imperial measurements.
      I think that the history of the propeller is from the Australian RAAF fleet SE-5a aircraft with the Australian Flying Corps.
        Hi Dave,
        After the Wright Bros made the first sustained powered flight, aviation gradually became moribund in the States. It was France in Europe that became the intellectual power house, particularly in the design of props and hence almost all prop dimensions were measured in mm.
        Enjoy your prop!
        www.aeroclocks.com
