Well, it's certainly different looking, and pleasantly so. It looks like WW2 era, but we'd really need to be able to read the stampings to have any hope of identifying it.
Need help with this one
Originally posted by Dave View PostWell, it's certainly different looking, and pleasantly so. It looks like WW2 era, but we'd really need to be able to read the stampings to have any hope of identifying it.Attached Files
After looking at the hub dimensions section it seems that this prop did belong to a WW1 era aircraft because of the engine specs but I found no exact matches. Obviously American or British as the writing is English. 8 hub holes. 7.5 feet long. Anything???Last edited by SGL66; 07-11-2009, 11:40 AM.
The hub dimensions don't mean that it was WW1 era, but those dimensions are found on many WW1 propellers.
I suspect the 42W likely references a 1942 military contract, but most of those I've seen are stamped 42K instead of "W". Certainly the design is more typical of later aircraft, but the RPM stamping is more typical of earlier.
Mystery to me, so far.Dave
Originally posted by Dave View PostThe hub dimensions don't mean that it was WW1 era, but those dimensions are found on many WW1 propellers.
OK, here's your answer. Go to this page to find the military number, then look up the 90HA-84 or -86 number on this page to find that it was used on a Ryan aircraft, either a PT22 or an ST3KR, both using 160 HP Kinner engines. And 1942 would then have been the year the contract was awarded, so it could have been manufactured then or any time after that, although I believe the type certificate expired in 1956.
Also, according to the type certificate data, the RPMs should be 1850, not 1650.Last edited by Dave; 07-12-2009, 12:34 PM.Dave
Originally posted by Dave View PostOK, here's your answer. Go to this page to find the military number, then look up the 90HA-84 or -86 number on this page to find that it was used on a Ryan aircraft, either a PT22 or an ST3KR, both using 160 HP Kinner engines. And 1942 would then have been the year the contract was awarded, so it could have been manufactured then or any time after that, although I believe the type certificate expired in 1956.
