DES89J Information requested
  • DES89J Information requested
    I have recently discovred a prop hub with following info stamped on it
    DES89J
    SER 8017 :
    RPM 2575
    HP 40
    Can you help me with manufacturer ID and aircraft used on
    Is this a metal hub or a wooden propeller with the blades cut off leaving a remaining hub?
      DES89J PRPP
      It is a wooden prop and I have only the hub and enough blade to contain the data. I have had it for many years and my feeling was that it was from
      a 40 horse Cub or bird of that era. Iwant to confirm the Manufacturer and approximate date of manufacture.
      Almost forgot, also have a full Lewis prop with the following stamped on the blade:
      DESL16-37 Ser 850 HP 65 RPM 2550.
      It is in nice condition with brass tip and leading edge and nice Lewis decal.
      Cheers
      Dick Atkins
        Unfortunately, it seems I have no information on either your hub or your full G.B. Lewis prop. Sorry.
          THANKS FOR TRYING!
            LAMAR
            THANKS FOR TRYING
            DICK
              possibility?
              Hello-
              I have a Sensenich propeller that is imprinted with:
              DES,69J,
              NO. 3766,
              A,T,O, 564,
              Maybe it is similar? Let me apologize if I am way off, here--I just found this forum yesterday when I was trying to find out what I had received from my Uncle Bill.
              Angel
                Thank you for trying to help Angel but it seems highly unlikely there's any relationship between the two props.
                Yours if for an Aeronca K C, a Porterfield CP40 or CP40A, a Taylorcraft A or a Welch OW5M each with a Continental A 40/40 hp engine.
