Old 06-26-2019, 06:41 PM   #11
v8sharkie
Understood.
Also, I was reading somewhere else that the SC prefix was used through 1918. Or did they use this stamping after 1918?
I had also read that the clover stamping is another indication of Signal Corps. Is that accurate?
v8sharkie is offline   Reply With Quote
Old 06-26-2019, 08:54 PM   #12
I don't know the answer to how long SC numbers may have been used, but I've seen some props that certainly suggest that it may have been considerably past the 1918 dates.
Might be a good research project.
Old 06-26-2019, 09:18 PM   #13
v8sharkie
No problem. Yes, that would be interesting to know more about.
Also, curious if you have any knowledge on the Signal Corps clover shaped stamp? It reads USA 76 inside each of the legs (U) (S) (A) (76)
Old 06-26-2019, 09:34 PM   #14
I suspect that it's an inspector's stamp, and 76 identifies the inspector. That's often the format in other countries.
identification, right hand, righthand
