Old 03-18-2006, 05:10 PM   #1
Fred Marks
Default Arsenal Propeller
This propeller was purchased at Ravenna Arsenal during the 1940's.Length 8' - Blade width 9 1/2"-Bore 2.730"-Hub dia. 7 3/4"-HUB thickness 4 1/4"-Bolt holes 8-13/32" Bolt circle 6"-weight 27#-Wood perhaps mahogany-Copper clad leading edges-6 laminations-#615 stamped on both sides of hub
Old 03-18-2006, 10:19 PM   #2
Forum contributor
The hub dimensions are consistent with use on a Hall Scott engine. One possible use is the Standard J1, but there are certainly other possibilities as well.
See this example.
Old 05-27-2006, 01:50 PM   #3
Doug
Fred,
The wood kind of looks like white oak, but it could be the photo.
Just my two cents if it helps.
Doug
