Old 09-06-2018, 01:13 PM   #1
Geertse
Default Garuda propeller
Can someone help me with following propeller data
Garuda propeller
Mercedes 160ps
D278 St197
Blattbr 025 or 028
What airplane type could it be?
Greetings,
Geert
Geertse is offline   Reply With Quote
Old 09-10-2018, 01:05 PM   #2
Geertse
Default Prop garuda
Hello Bob,
Could you help me considering the info I have?
Diameter 278 pitch 197
160 ps mercedes
Garuda
Thxs,
Geert
Old 09-11-2018, 06:05 AM   #3
Hello Geert,
Good to hear from you again.
I appear to have missed your post above, for which I apologise. I was in hospital and recuperating around that time.
Your data translate as;
(I know you understand this as well as I do but this note is also for fellow forumites who might be less well versed in our subject. )
Garuda Propeller The German propeller maker
Mercedes 160ps The aircraft engine of about 160hp
D278 The diameter of the prop in cm
St197 The pitch of the prop
Blattbr 025 or 028 The blade width (only Garuda added this measurement to the hub data)
I have recorded eighteen Garuda props for the Mercedes 160ps of which I can identify six to a known type of aircraft, all of which were Albatros types.
The prop with dimensions nearest to yours with D2750 and St1970 was fitted to an Alb D.V (This data came from Koloman Meyrhofer, the Austrian restorer and builder of German WW1 aircraft). A prop with D2740 and St 2000 was fitted to an Alb D.II brought down by the British late in 2016.)
Old 09-11-2018, 10:26 AM   #4
Geertse
Default Prop
Hello Bob,
Hope your health is ok by now.
Thank you very much for the reply!
So itís most likely from an albatros dv.
Great to hear that.
Greetings,
Geert
Old 09-12-2018, 09:57 AM   #5
Glad to help Geert!
