Old 01-25-2008, 05:53 PM   #1
Sam Anderson
Guest
Posts: n/a
Default USN Falcon propeller
Help! I am trying to figure out what era and aircraft my propeller is from.
Description:
-Falcon decals
-98" tip to tip
-copper on ends of tips and leading edges
-anchors and "US" stamp on each blade
-4" thick hub
-69mm interior hub diameter
-8 bolt holes
-6" hub diameter
-appears to be oak
-5 1/2" bolt hole cirle
The following is what and how the blades are stamped:
2.
8.2.. X 5. (periods are stamped at top of numbers)
S.E. /-/ 100 /-/ 128 (backslash are really straight up)
Other blade:
1286.
10001.A.
T.M.
Thanks for any info. in advance,
Sam
Old 01-25-2008, 06:43 PM   #2
That number (10001) shows up on a list labeled "Propellers for F boats, model 40, and MF boats, 100 HP OXX 3-6 engines (pusher).
Can you post a picture?
I presume the Falcon decal is listed as Jamestown?
Old 01-26-2008, 03:17 PM   #3
Sam Anderson
Guest
Posts: n/a
Thanks for the info. Dave. I will do a little research on those listed boats. Any clue as to what kind of value a good condition one might have?
Thanks again,
Sam
Old 01-27-2008, 07:25 AM   #4
It depends on what "good condition" means.
