old wood prop
  • old wood prop
    Can anyone help me identify this prop? I have an 80+yr old friend who has a prop that needs to be identified. the markings are
    5682 64 DES.86R-64 TC- 81Y F8-4 FG-4.
    Please see 86R61 here: http://www.modernwoodenpropellers.com/sensenich.htm. The only difference is the pitch of 64.
      lamar, can you give any history on the prop , ie year,origin ect? thanks
        Does your prop have the name Sensenich stamped into the wood on the hub or at a blade root?
          it's my friends. i know the one side doesn't, but i have to check the other side. i think the only markings are the #'s.
            Lamar, it doesn't have a name on the other side. Do you know what kind it is? thanks Joe
              I have a military id of 42K15729. Can anyone define or give me info for it. thanks.
                That tells you that it was manufactured under a 1942 military contract, but the actual manufacture date could be later than that.
                The number cross references to 86 -R61, which was used on the Fairchild or Fleet aircraft listed for that number.
                  thanks dave. i have another #. Do you know what it is? Any help would be apreciated. Thanks DES.86R-64 5682
                  64
                  F8-4
                  FG-4
                  TC-81Y
                    5682 is probably the serial number. I don't know about the rest. Usually "TC" stands for "type certificate" but it's usually a 3 digit number.
                      dave, thanks for your help.
