Old 02-07-2008, 04:37 AM   #1
ramart
Guest
Posts: n/a
Default JPW decal
I am looking for an advice from this great source of knowledge and information. I have a propeller stamped on hub side
INTEGRAL PROPELLER
D R P
N 236
D230 S185
80PS GNOME
Unfortunately, the whole prop is covered with a thin layer of an old silver paint, probably synthetic. In certain light conditions I can see on propeller leafs a relief of decals with JPW letters in a round frame.
I would like to remove this ugly silver paint, but otherwise leave the prop as much as possible in the state as found. So far I was not successful with any from common, easily available solvents tried (acetone, perchloroethylene, several brands of synthetic paint thinners, Loctite sealing cleaners, etc.), and am slowly inclining towards a mechanical method of patient removal of the silver paint. The biggest problem I see is how to preserve JPW decals during the paint removal effort.
I would like to learn about decals: how are they made, if there is a chance they are covered with a protective varnish layer (probably not), etc. Also, if anybody would have any advice regarding the prop, I would be very thankful to read it.
Thank you in advance
Martin
Old 02-07-2008, 05:24 AM   #2
Hello Martin and welcome to our website.
The lettering on your prop indicates;
Made by the German subsidiary of the French Integrale Co
Deutches Reich Patent
Serial number
Diameter 2300mm Pitch 1850mm
80hp Gnome engine. This was French but also used in Germany.
I'll post some photographs of an Integral decal in a moment
With regards,
Old 02-07-2008, 06:08 AM   #3
Here are photographs of original Integral decals and of a modern reconstruction by Abufletcher, a fellow forumite.
Old 02-07-2008, 06:23 AM   #4
Martin,
It is unlkely that you can recover the decals because;
They are fragile with age
The silver paint will have damaged them
The protective coat of varnish over them will be softened by the solvent in the silver paint.
But this does not mean you should not try. The method, which requires considerable patience, is to forensically remove the silver paint with very fine grade abrasives. You'll have to experiment on some other part of the prop. Try the softest possible grade of wire wool and the least abrasive sheet of wet and dry. If it is possible to remove the paint it will take many hours of work to expose the decals. Good luck.
Old 02-07-2008, 06:25 AM   #5
Postscript;
Your prop probably dates from 1914 and is probably from an early Fokker E type.
Old 02-08-2008, 04:36 AM   #6
ramart
Guest
Posts: n/a
Thank you very much for your kind words!
Martin
Old 09-25-2013, 08:19 PM   #7
hiperlightflyguy
Guest
Posts: n/a
We at Nostalgic Reflections have been making vintage water slide Propeller Decals for 41 years + We can make most any of them, but we don't make them on speculation, just real orders. They have had our contact information listed for years, but I couldn't find it right now but you can get in touch with us either through this site or nosref@peoplepc.com and we will help you with your project. Jerry Turner.
Originally Posted by ramart View Post
INTEGRAL PROPELLER
D R P
N 236
D230 S185
80PS GNOME
Martin
