A strange propeller
  • A strange propeller
    I am a french merchant (Paris) and I would be pleased to have your opinion about a quite special propeller.
    It is a Chauvière Integrale (260 cm / 102.36”) with a 8 bolt holes hub (diameter 20.5 cm / 8.,07” and center bore 7cm / 2.76”) with a large metal plate fixed on the back of each blade. It is a very strange assemblage because the metal doesn’t stick at all to each blade (a spacing of 4 cm / 1,57” near the trailing edge)
    I never seen anything like it before. It could be an armour plating (with bullet impact ?)... but how can a blade work with such a shape ?
    I placed some pictures on a temporary website : http://pagesperso-orange.fr/aviaspot/prop.htm
    Have you ever seen this kind of propeller ?
    Thank you for your help !
    Philippe
    Bonjour Philippe !
    Chauvière serial 2276 is referenced in the WW1 military books I have:
    Diameter: 2m55
    Pitch: 2m30
    Blades: 225 mm wide
    Hub thickness: 150 mm
    Central hole: 70 mm
    Fixations: 8 bolts (11 mm holes on a 150 mm circle)
    Chauvière serial 2276 was approved for school use on a SPAD fitted with a 110 HP Le Rhône. It seems 2276 is an early Chauvière serial.
    So, all markings I can read on your prop fit (I can read only one letter of the aircraft code on your picture "091003_helice_detail_1.jpg", but it is a "S", so it could be a Spad (please, try to read it all: it have to be "Spa"). The only difference is diameter (2m60 vs 2m55): are you sure about your measurement?
    Your prop has the airworthiness stamps, so this very one was approved for military use as a "normal" unit. Normally, there are three others on one of the flat sides of the hub, with two numbers. Could you give a look? Perhaps they have been removed when the metal plates were fitted ... And, please, could you tell what is near the stamps (I read "M" on one picture, but I don't read the other for sure).
    As the Chauvière decal is under the metal plate, I think those metal plates were not fixed in Chauvière workshop. But the prop number (30001) seems very special and could be a special work the militaries were using at the time they tried to fire guns through airscrew circle (1916 ?). Alternatively, as the prop was for school use, a protection for clumsy shooters?
    If you want to sell this prop, let me know: we are trying to make a "prop museum" in Figeac, and the right place for your prop is a museum if my guessing is correct. You can also try to show it at "Les Ailes Anciennes" at Duny near MAE. If you are able to see them, I am sure they will be interested.
    And, please, resist the desire to restore it ! See http://woodenpropeller.com/forumvB/showthread.php?t=674
    Best regards,
      Bonsoir "pmdec",
      I am very impressed !!!!
      Thank you very much for all those informations !
      I placed better pictures online but unfortunately there is no other marking than those shown.
      I apologize for my quick measurement. You are right the diameter is exactly 2.55 m !
      This propeller is for sale, but I am not sure that any museum can consider the price asked by the owner as reasonable ...
      Best Regards,
      Philippe
