Garuda propeller
  • Garuda propeller
    Can someone help me with following propeller data
    Garuda propeller
    Mercedes 160ps
    D278 St197
    Blattbr 025 or 028
    What airplane type could it be?
    Greetings,
    Geert
    Prop garuda
    Hello Bob,
    Could you help me considering the info I have?
    Diameter 278 pitch 197
    160 ps mercedes
    Garuda
    Thxs,
    Geert
      Hello Geert,
      Good to hear from you again.
      I appear to have missed your post above, for which I apologise. I was in hospital and recuperating around that time.
      Your data translate as;
      (I know you understand this as well as I do but this note is also for fellow forumites who might be less well versed in our subject. )
      Garuda Propeller The German propeller maker
      Mercedes 160ps The aircraft engine of about 160hp
      D278 The diameter of the prop in cm
      St197 The pitch of the prop
      Blattbr 025 or 028 The blade width (only Garuda added this measurement to the hub data)
      I have recorded eighteen Garuda props for the Mercedes 160ps of which I can identify six to a known type of aircraft, all of which were Albatros types.
      The prop with dimensions nearest to yours with D2750 and St1970 was fitted to an Alb D.V (This data came from Koloman Meyrhofer, the Austrian restorer and builder of German WW1 aircraft). A prop with D2740 and St 2000 was fitted to an Alb D.II brought down by the British late in 2016.)
        Prop
        Hello Bob,
        Hope your health is ok by now.
        Thank you very much for the reply!
        So it’s most likely from an albatros dv.
        Great to hear that.
        Greetings,
        Geert
          Glad to help Geert!
