have come into my possesion a wooden prop 103 inches in length,hub diameter 10.5 inches hub thickness 7.25 inches hub centre bore3.5 inches bolt hole diameter c to c 7.7/8 inches 1/2 inch bolts there has also been an 8 hole bolt pattern that has been plugged off 5.5 inch diameter c to c.markings on one side of hubas follows No 907 1354 k+w thun . other side of hub as follows d260 s 285 500 ps hs motor d27 any help wood b appreciated in id ing this prop. it also appears to have a bullet gone thru one of the blades any help on value wood b good to .thanks in advance
wooden prop
Your prop is probably German made and probably dates from the 1920s.
The diameter is 2600mm and the pitch is 2850mm, a combination which hints at an engine with reduction gearing to the prop. The horse power is 500.
It may have been made by Heine. It might possibly have been made for a Swedish aircraft.
If you could post photographs of the complete prop and of the data stamped on the hub, I might be able to help further.
Originally posted by craneguy View Postany kind of value. does the bullet hole have any effect or shud it b repaired
A bullet hole adds value if it's authentic and occurred in combat. You shouldn't try to restore or repair anything on it. Its value is as a display piece, not an airworthy part, so keep it original.Dave
bob or dave wood b easier if i had email add to send pics
Edit: pics added to original post.
Here is the bullet entrance hole pic, I believe.Attached FilesLast edited by Dave; 01-07-2010, 04:22 PM.
It may not have been a warlike bullet. I don't think the Swiss have been to war for six hundred years. But they might have sold some aircraft for export which were used in combat. Or someone might have just fired a round off at it in Canada.
If you google the name of the company who made it, Eidgenössische Konstruktions Werkstätte, or K+W Thun, you might be able to discover the type of aircraft and if any were exported.
My advice is to sell it on eBay. Make sure that you tick the box for 'worldwide' so that it is visible in Switzerland. Make sure that use the names Eidgenössische Konstruktions Werkstätte, and K+W Thun.
It's value can only be guessed at until proved in an auction but I think it might sell to a Swiss for around 1000 USD.
BobLast edited by Bob Gardner; 01-08-2010, 12:02 PM.
