Old 02-08-2007, 03:01 PM   #1
Woody
Guest
Posts: n/a
Default Propeller ID
Hello, nice website. I have a propeller that I would like to have identified. It is 9' 3 " long, 8 bolt holes about 1/2"(someone added 2 more holes? slightly smaller) holes are about 7 1/4" apart hub is 10 3/4" across (wood), Thickness of hub is 5" bore hole ( not sleeved ) 3 1/5" The only markings that I found is " SC 62769 " with a cartouche in a square, I am unable to make it out. The prop is hanging so I cannot see all of it clearly. I will post photos at a later date.
Old 02-09-2007, 12:40 PM   #2
dbahnvt
Guest
Posts: n/a
The "SC" number refers to Signal Corps, but is otherwise not helpful. There may be other numbers that you can't see that would help, as might the picture.
Old 02-10-2007, 05:23 PM   #3
Woody
Guest
Posts: n/a
I have no place to post my photos to as of yet. Also stamped on the face of the hub is 9 3 6.75 righthand. The mounting plate looks to have been about 13 inches across. I will attempt to post photos later. No other writing or numbers appear on the propeller. Thanks
Old 02-10-2007, 10:15 PM   #4
You can post them on photobucket.com for free. See this link.
