Old prop marked DES
  • Old prop marked DES
    Can someone assist me with ID ing an old prop that I've had since 1956? Its marked, DES. H56 L.X.R.H. NO.12324 on the hub it has 465 - 5 over 8 circled bolt holes. Its tappered hub 10" in front and 15" in back and is 4 and 1/2 inches thick. The prop itself is over 82" long(the tips are broken from the last landing) and it has a thin metal protection on the leading edges starting 11" from the hub to the tip. Bob G. 586-932-6261
    Can you post a picture? I don't recognize the drawing number, but I'll check through some references at home.
      Here are some pictures.
      It's going to be hard to identify it in the absence of a full drawing number.
