Old 04-24-2019, 02:21 AM   #31
ahranis
Followed your steps.
I did the best I could.
A1(0.9 m): 16,7 degrees
A2(1,0 m): 15,9 degrees
A3(1,2 m): 14,4 degrees
I am not sure what tg(x) stands for.
Is it tan(x)?
Anyway, hope this helps!
ahranis is offline   Reply With Quote
Old 04-24-2019, 02:39 AM   #32
ahranis
A1: 186*3,14*1,53=894
A2: 200*3,14*0,19=119,38
A3: 240* 3,14*(-3,72)=-2.804,81
Doesn't seem good to me
I am sending the prop there for examination...
Old 04-24-2019, 02:47 AM   #33
ahranis
Never sent this
Old 04-24-2019, 03:26 AM   #34
ahranis
Doublechecked it.
Flat side of the blades again.
Same readings.
On the other side of the blades, the angles tend to be more close to the diagram you attached but I can not take safe readings because of the curves.
Old 04-24-2019, 04:06 AM   #35
ahranis
I think I found my mistake.
The angles I measured are between the flat side of the blades and the flat side of the hub.
But you asked for the degrees between the flat side of the blades and the rotation plane. So...
Is it ,
A1: 90-16,7=73,3
A2: 90-15,9=74,1
A3: 90-14,4=75,6
seems worse now
Old 04-24-2019, 06:35 AM   #36
Yes, "tg" is tangent, but to compute the tangent, Excel and some calculators need to convert the angle in radians first... So the pitch is (Excel formula):
P = 2 * PI() * r * TAN(RADIANS(angle))
where "r" is the radius and "angle" the angle in degrees.
By the way, I have some interesting answers about Salmson aircraft in the French forum, specially somedy who wrote that the Salmson-Moineau SM1 AC2 engine was adverted for 260 HP in 1932 in a Salmson brochure. Yes, it is late, but it would explain where a right handed propeller could be used with a 260 HP Salmson engine. The problem is I don't know what is the gear ratio in this very strange mechanics of the SM1 aircraft!
I will come back this evening or tomorrow...
Old 04-24-2019, 07:36 AM   #37
Wow!
Who would have thought when Dave Bahnson started this forum that it would produce such erudite correspondence.
With reverence,
Old 04-24-2019, 09:58 PM   #38
Bad news: I have found two props used on the Salmson-Moineau SM1 but the data "tell" that the prop rotational speed was less than the engine.
Salmson prop serial 18 and Régy prop serial 331 had identical caracteristics with a 295 cm length, 265 cm pitch and a 255 mm blade width. The larger diameter, length and pitch vs the props for Salmson 9Z are from a rotation speed largely lower.
The ahranis prop, with a length of 279 cm and a pitch less than 2 meters, cannot be used for this plane, and it is the only plane I have seen (which is far from a proof that there is not one!) with a right handed prop.
Anybody an other idea?
Perhaps interesting to note : there was a Régy serial 372, the first*** Régy for Salmson 2A2 with a Canton-Unné Z9 which was 280 cm length, had a 210 cm pitch and a 233 mm blade width. This is quite the same that ahranis prop. But all pics show a left handed prop on this aicraft... Is it possible to make the engine turning the other way for whatever raison?
*** Replaced later by the 804.
Old 04-24-2019, 10:09 PM   #39
I've seen opposite thread props for a Bristol airplane, but it was a twin engine aircraft so the counter-rotating propellers had a certain advantage in neutralizing the adverse yaw forces that were inherent in any propeller. I suspect it's not overly complicated to reverse the engine rotation from an engineering standpoint, but why would that be done for a single engine aircraft? I certainly don't have an explanation.
Old 04-25-2019, 05:06 AM   #40
ahranis
What about these?
It was a training plane manufactured in Greece using a Salmson engine.
https://www.haf.gr/en/history/histor...lidwn-swallow/
https://en.m.wikipedia.org/wiki/KEA_Chelidon
Maybe other planes were modified after the end of the war to serve civilian causes.
I know I often say things that you already know.
Just trying...
or these two
https://www.haf.gr/en/history/histor...ulnier-ms-147/
https://www.haf.gr/en/history/histor...t/hanriot-41h/
... and I am Stopping now
