Old 01-22-2019, 10:20 AM   #1
Standbyme
Default Identify Thanks
Located in Wolfeboro New Hampshire
Length 9ft 3in
8 bolt holes
Badge:Hallett Davis Piano Co
Aeroplane Department
Standbyme is offline   Reply With Quote
Old 01-22-2019, 11:14 AM   #2
It can't be identified without stamped information around the hub, but at a glance it looks very similar to props made for a Liberty engine, often to power a DH4 or some of the Navy's flying boats in the late teens, early twenties.
If the bolt holes (behind the plate or seen from the other side) are 1/2" in diameter and their centers are 8" apart across the widest diameter (that's the "bolt hole circle") then it's very likely for a Liberty engine. The absence of metal sheathing suggests that it was not as likely to be used on a flying boat.
See if you can find numbers stamped somewhere around the hub or the inside of the blade.
Old 01-22-2019, 05:30 PM   #3
Standbyme
Thank you for the information. I saved it from the curbside. I have made up a bunch stories over the years as to itís history. Glad to have legit information going forward. Go Pats!
