Old 11-14-2018, 02:48 PM   #1
Halberstadt
Default 1916 Curtiss S-1 Propellers
Hi to everyone!
Im new in the forum and trying to identify the two types of propeller known to have been fitted to the Curtiss S-1 of 1916 (see the attached images). I need to draw them to scale, so their diameters are most important to me.
Any advice from you will be greatly appreciated.
Halberstadt is offline   Reply With Quote
Old 11-14-2018, 03:27 PM   #2
That's a difficult task. Are there any numbers stamped around the hub?
Old 11-14-2018, 05:21 PM   #3
Halberstadt
I can't see any numbers nor stamps when zooming the photos I have.
Paragon apparently manufactured models similar to them.
Old 11-14-2018, 08:36 PM   #4
Unfortunately, there were thousands of different models of propellers and many different models look almost exactly like other models. Even with data stamped on them, they can be very difficult to identify. There were 25,000 Paragon propellers manufactured before the end of WW1, and they continued for some time after that..
There seems to be a big difference in the two propellers pictured, the lower one more typical of an early, low powered engine. I'd have to do a little more research but there was also S1 actually a Mercury S1 from 1931. this page.
Is it possible that the photos are from different models altogether, both with an "S1" designation?
Old 11-14-2018, 10:16 PM   #5
Halberstadt
The Curtiss S-1 was a one-off prototype for a single seater fighter, some data on it is available on this website:
http://ivanpwheaton.blogspot.com/201...eed-scout.html
Apparently, it was formerly fitted with the low pitch propeller and later fitted with the high pitch one. With the later propeller, the plane was somehow damaged (see the attached images, all of them correspond to the same machine).
