Old 05-26-2015, 12:33 AM   #1
AFBreest
Default Identifying WWI prop
Thanks for setting up this forum! My dad just passed down his WWI propeller to me that he bought from antique shop in London 30 years ago. He was told at the time it came from an Avro that flew in WWI.
Any help in identifying what aircraft it came from would be appreciated.
The markings on the prop are:
DRG P23
D 8-5' P 6-10
TR_CTOR( I couldn't identify the 3rd letter)
110 CIERGHT RH(not positive on the IE)
1579( not positive on the 9)
The final markings include four small boxes right next to each other with the same markings- they are:
A.I.D.
357
See pictures posted as well.
Thanks in advance!
Best,
Andrew
- Andrew
AFBreest is offline   Reply With Quote
Old 05-26-2015, 12:34 AM   #2
AFBreest
Additional photo
- Andrew
Old 05-26-2015, 12:38 AM   #3
AFBreest
Extra photo
- Andrew
Old 05-26-2015, 12:39 AM   #4
AFBreest
Extra photo 4
- Andrew
Old 05-26-2015, 12:40 AM   #5
AFBreest
Extra photo 5
- Andrew
Old 05-26-2015, 09:07 AM   #6
The drawing number, P23 is listed for use on a Nieuport, although it doesn't specify the model. Other markings indicate a Clerget 110 HP engine, Right hand tractor application, and diameter and pitch.
The AID is an inspection stamp from the Aeronautical Inspection Department
Old 05-26-2015, 05:00 PM   #7
The shape is strangely like Régy French props!
Could you post clear close-ups of the two "flat" sides of the hub?
And give the exact length of the prop?
Old 05-26-2015, 09:21 PM   #8
Originally Posted by pmdec View Post
I noticed that as well. It looks very similar in design to this Regy
prop
Old 05-26-2015, 09:37 PM   #9
AFBreest
Thanks for the quick feedback!
I just measured the prop and it measured 8 feet 5 inches. Which makes since with the marking
D 8-5'
Additionally, it appears there's an additional number on the prop but it's quite faded. I believe it's 13. It appears above the name of the 110 CIERGHET RH line.
Also, attached is a more detailed photo of the flat portion of the hub.
- Andrew
Old 05-26-2015, 09:38 PM   #10
AFBreest
Thanks for all of the help thus far!
Picture 2
- Andrew
