Old 04-11-2011, 05:22 PM   #21
dairwin
Originally Posted by Bob Gardner View Post
Thank you David!
Please keep us up to date.
Bob,
In the two months since my last messages, there has been several advances relating to this propeller.
The research has yielded only five drawings of the hub, and no further information on the blade type. However, there is now sufficient information on the hub to dismantle it fully. Also, the blades are likely to be like all early (late 1930s) Rotol blades; a clarke-y section and simple/tapered blade roots.
In the last week I have had tools fabricated to unscrew the two castellated nuts per blade, and the removal of the blade adaptors from the hub. Inside, there is light corrosion, but the running surfaces for the variable pitch cylinder are corrosion free (still full of engine oil).
I have located similar rotol blades for another R5 propeller, and will assess whether these can be used as a basis to fabricate a set appropriate for the R5/3 hub.
I will send you a PM as well.
Kind regards,
David.
dairwin is offline   Reply With Quote
Old 05-17-2012, 08:57 AM   #22
dairwin
Default re: R5 and Watts
Thank you David!
Bob,
It has been a several months since my last posting regarding the Rotol R5 propeller I am rebuilding. Work on the R5 blade adaptors is now advanced, and I plan to start the wooden blade fabrication later this year. The hub has been restored in readiness for the blades.
However, I would also like to fit the engine with a Watts prop, but as they are not available, I would like to evaluate what is involved to replicate one for ground running.
I know at least one forum member who has restored a Watts I am keen to acquire information on the blade dimensions, profile, photos of restoration, etc.
On a separate but related note; in order to fabricate the wooden R5 blades (and a Watts if I do) I am looking for a blade duplicator machine. I am having problems locating one suitable to make blades of 4 feet length (8 feet prop diameter). I would welcome advice from members.
Kind regards,
David
Old 05-19-2012, 06:15 AM   #23
Thank you, David, for keeping us up to date. I remain impressed by what you do.
As a general observation, I think you should contact all the Merlin rebuilders in the country, if you haven't already. They will be interested in your work and they might have some lifed bits, about to be scrapped.
Guy Black had a prop replicating machine when I last saw him. He bought it on eBay. I'm not sure it works, but ask him. He also restores vintage aircraft and has an engine restoration company, Retrotec. He owns a flying Spitfire Mk. Vb (G-MKVB), Hawker Hurricane XIIa (G-HURI), Hawker Nimrod II (G-BURZ) and Hawker Fury (G-CBZP)
A company in the South West, Spitfire Spares, makes replica WW1 props using a period prop copying machine. I think they are the people to make blades for you. You'll need a blank or existing blade to copy. Presumably for running at low revs on the ground a solid prop rather than a laminated one would suffice? It would be easier.
I'll e-mail both of them to let them know you'll be in touch.
Please keep updating us.
Old 05-19-2012, 06:27 AM   #24
dairwin
Thanks Bob for your reply.
Please see my PM.
David
Old 05-19-2012, 07:56 AM   #25
As an afterthought, we have restored several wooden fixed-pitch props designed by Dr HC Watts and made by the Airscrew Company, which include one Spitfire prop, two Hurricane props and a Kestrel prop. But we have no details of them other than dimensions and pitch. The same hub fitments were used on both the Spit and the Hurricane fixed pitch props, so from your point of view either prop would fit your Merlin.
Old 05-19-2012, 05:11 PM   #26
dairwin
That is very interesting, as these are the props I am interested in; specifically the Hurricane Watts, as the engine in question is configured for Hurricane use.
I understand there are several Hurricane Watts propellers, but they all seem to have the same diameter of 11.25' and a pitch of 21.3'.
DAI
