Wooden Propeller Forum (http://woodenpropeller.com/forumvB/index.php)
-   Show and Tell (http://woodenpropeller.com/forumvB/forumdisplay.php?f=17)
-   -   Curtiss Jenny Canada Propeller (http://woodenpropeller.com/forumvB/showthread.php?t=3849)
Cyril1969 07-18-2018 11:18 PM
Hi new to here.
I have a wooden propeller that appears to be from a Curtiss Jenny made in Canada. Stamp markings on what I believe is the face side is as follows: each edge of the hub towards the blades are a circle stamped with A I D 0 2 inside the circles. Below one circle is 8-3 X500 and below that is RIGHT HAND. Below the other circle is 137 below that is a small rectangle stamped with CA LTD 41 inside it. Below the rectangle is 5079 and below that is A.J. Edmonds. Hub wood diameter is 7 1/2 inches, hub thickness is 4 inches, centre hole is 2 11/16 inches, widest point on blade is 8 7/16 inches, 8 holes spaced 2 inches apart and 5 1/4 inches across. This propeller is in what I would call 80 to 90 percent condition. Any help identifying this propeller would be greatly appreciated.
Thanks Cyril
Will put up pictures once I figure out how to do that if anyone wants a look.
Dbahnson 07-20-2018 08:19 AM
Pictures might help. In the meantime see this thread from the past.
This thread also has some discussion of AJ Edmonds.
The 5 1/4 inch bolt hole circle is consistent with an OX5 engine, but that engine was used on a variety of aircraft, the Jenny being one of them.
Blackmax 07-23-2018 11:08 PM
Is the prop goin to be for sale
PropArt 07-24-2018 09:05 PM
send over some photos to planepieces@gmail.com and I will tell you what it is.
Cyril1969 08-01-2018 08:43 PM
Have just placed the propeller for sale on Ebay
Dbahnson 08-01-2018 09:38 PM
It's very likely that no one will see it without a link or a searchable description.
At the very least you should list the ebay item number, but even that will only be seen by a limited audience.
PropArt 08-02-2018 08:54 AM
Found the listing on the Ebay Canada site here:
https://www.ebay.ca/itm/Vintage-WWI-...y/153123009141
Appears to be another replica. These are popping up everywhere now. Be cautious.
PropArt 08-02-2018 08:58 AM
Here is another Jenny replica that was sold the other day. I talked to the buyer and they didn't even read the description before buying (their fault). Totally thought it was the real deal.
https://www.ebay.com/itm/WWI-Curtiss...-/123199242374
